MF35 thrust washers?
MattM
12-20-2005 14:25:36
It's a 1967 Mf35 Perkins. During oil change, cleaned sump screen out for first time. Two metal pieces fell into the drain pan. Put together, they make about a 5 inch circle, 1/4 inch wide, 1/16 deep. One has an extra tab on the outside of the circle. Only part that looks like that in my parts and service manuals would be the thrust washers from the main bearings. Can they come out with the caps in place? Engine was rebuilt before I bought it, hoping these are old parts left behind. Tractor seem to run well. How can I tell, without tearing whole thing down, if I need to tear the whole thing down?
DavidP, South Wales
12-20-2005 14:44:56
 Re: MF35 thrust washers? in reply to MattM, 12-20-2005 14:25:36
Hi,
Definately looks like the old thrust washers are in the sump. Who on earth did the job and left them there? With the underside of the rear main bearing housing clear of oil you can see the tag between the crank journal and the cap. If you haven't removed the sump the best (and only) way is to check the end float in the crank. It should be absolutely negligible in a rebuilt engine but if you have positive movement you need to remove the sump at the very least. You cannot remove the rear main cap without removing the engine and removing the back plate. Good luck.
David P
