444 bell housing ?
Dale L
12-19-2005 17:08:26
Does anyone know if a MH 44 bell housing is the same as a 444' or any other model. I'm restoring a 444 and the clutch bell housing has part of the casting broken off. I see it broke off on other MH tractors at the same place,right by an alignment pin[dowel].
treefeller
12-19-2005 17:31:24
 Re: 444 bell housing ? in reply to Dale L , 12-19-2005 17:08:26
I'm not positive, BUT I think it is. But if I;m wrong, cut a piece of mild steel and get some nickel rod and weld the ear back on. Any welding shop can do it if you don't have a welder. Just cut the piece of mild still the shape it needs to be to make it like the other side. Grind out both pieces into a V and put them together and weld them.
