Massey 135
Dantanner
12-16-2005 10:15:49
Hi.Below where the speedo cable screws in on my Massey 135 There is oil weeping out of a small hole.Is this hole supposed to be there,if so why , what would happen if i blocked it up?
DavidP, South Wales
12-16-2005 12:42:20
 Re: Massey 135 in reply to Dantanner, 12-16-2005 10:15:49
Hi,
Yes the hole is supposed to be there. If you blocked it up you would probably have your tractormeter filling with oil. It allows any oil that passes the seal to escape. If your oil loss is at the point of concern it is time to change the seal in the triangular plate. The seals go hard or split with time. It's quite a common problem.
The items you need are;
Seal 30854 (636 762 M1
Gasket 36862511
Remember to fit the seal so that the garter spring is visible with the seal in place.
Cheers
DavidP
