TYPE A ATF
LES EBERT
12-15-2005 17:22:59
I OWN A MF 204 WITH REVERSOMATIC TRANSMISSION. NEED HELP LOCATING TYPE A AFT OR APPROVED SUBSTITUE.
Don-Wi
12-18-2005 21:01:43
 Re: TYPE A ATF in reply to LES EBERT, 12-15-2005 17:22:59
Typa "A" turned into Dexron/Mercon III transmission fluid. Many people use hydrauluic oil now in other tractors that call for it, like Olivers that used it in the Hydra-Power (2 sp.)and Hydraul Shift (3 sp.) units. I run Dex/Merc in my Olivers, but hydraulic oil will have no ill effects.
Donovan from Wisconsin
msb
12-15-2005 18:49:56
FA(Ford) is type A amd John Deere Low Viscosity Hy Gard is essentially the same without the red dye in it.
