MH 44 PTO speed
William Brown
06-01-2000 14:19:42
Does anyone know the pto speed rating? I want to hook up a JD Mower Conditioner that uses a 540 rpm pto input.
Tom from Ontario
06-04-2000 17:53:00
 Re: MH 44 PTO speed in reply to William Brown, 06-01-2000 14:19:42
Exactly. If you don't want to run at full throttle due to noise, field conditions or some other factor, you'll have to drop a gear. When doing something like this without live or independent PTO, it can be beneficial to run a little slower in ground speed so the machine and tractor can cope if you hit a tough spot. Remember when you hit the clutch, it all stops.
Don
06-02-2000 02:39:01
William
You are safe. 44's are rated for 540 rpm, at the pto
William Brown
06-02-2000 18:39:48
 Re: Re: MH 44 PTO speed in reply to Don, 06-02-2000 02:39:01
What is the correct engine speed? Is the pto supposed to stay engaged on the first pary of the clutch? Or maybr they don't have a double clutch? I am having trouble with the clutch and I'm not sure if I should split the tractor and repair it. Thanks for the info.
Tom from Ontario
06-03-2000 20:41:09
 Re: Re: Re: MH 44 PTO speed in reply to William Brown, 06-02-2000 18:39:48
Wind her up all the way. You get PTO at full throttle. Ordinary 44's had transmission PTO's and the ones that had live power got it with a separate hand clutch, no two stage foot clutches in them
William Brown
06-04-2000 08:29:52
 Re: Re: Re: Re: MH 44 PTO speed in reply to Tom from Ontario, 06-03-2000 20:41:09
Your right, it is a transmission pto, only one drive shaft.
I turned it by hand and got a 2.5 : 1 ratio. I would assume that the engine governor should be set at 1350 RPM to yield 540 on th PTO. Does this sound about right?
Don
06-05-2000 14:08:15
 Re: Re: Re: Re: Re: MH 44 PTO speed in reply to William Brown, 06-04-2000 08:29:52
You are correct. the pto is a 2.5 to 1 ratio from the engine. your engine should free rev 1500rpm, producing 600rpm at the pto. the h260 is rated at 1350 rpm/540 pto. for a lot of jobs, you can run at 1/2 to 3/4 throttle, saving fuel and noise!
