MF1105 tractor hydraulic pump
Tom's Ranch
12-13-2005 13:41:28
need info on how to install oil seal on the hydraulic pump for the MF1105 tractor I know the parts manual says I need a expander tool that is fine but how does one expand the seal enough so as to get it over the spline shaft with out bracking it the first one I broke
barnrat
12-14-2005 07:47:12
 Re: MF1105 tractor hydraulic pump in reply to Tom's Ranch, 12-13-2005 13:41:28
I just put one in my 1130 and had aheck of a time with out the tool. I kept rolling it up on a tapered socket till I got it to the right size. Then rolled it in place. It wasn't easy and I had some really sore fingers when I was done. I'd recomend finding the tool.
Big Dean
12-14-2005 07:45:54
That tool is a very thin sleeve that goes over the splines of the shaft the top is cone shaped you put the tool over the splines lubricate it and the seal good I always used STP Start working the seal down the tool it will stretch ove the tool and slide down it not easy but I have Installed a lot of them and never split one I always removed the spring on the seal and installed it over the tool first then put it back on the seal after I had the seal in place. I have a drawing of the tool some place I can send you if you would like to see what it looks like
