MF 135 - tranny/differential oil questions
Way Up Here
12-08-2005 13:19:06
For a MF 135 gasoline Perkins, does a guy use the "Hy-Trans" type fluid in the differential/hydraulic system? If not, what is recommended? And how about the tranny, is it part of the rear end/hydraulics or is it separate? And if separate, what is recommended? Any information on capacities is also appreciated. Thank you for the information.
Brad-inTN
12-10-2005 20:44:58
 Re: MF 135 - tranny/differential oil questions in reply to Way Up Here, 12-08-2005 13:19:06
My 165 manual(should be same lube as 135)says "Use oil,specification M-1129...this is the only type of oil recommended for use in this system". Any quality universal type trans/hydro oil with the 1129 spec should work.
jerrycpp
12-09-2005 05:31:24
I use premium hydraulic fluid in my 135 Perkins gas. I get mine at Costco, but NAPA has it also, about $25 for 5 gallons. I think a full change takes 8 gallons. It is the same fluid for transmission, differential, and hydraulic. The only filter is a screen. You access it through the left inspection plate - the one with the pto shift lever. Unscrew the screen, clean and blow it out, and put it back in. Where I live the temperature goes from -20 to +105. This fluid works in all temps.
