50 ferguson
Tony in Tenn
12-06-2005 16:50:34
I just bought a 50 Massey Ferguson diesel w/power steering from a elderly man about 25 miles from my farm. has been sitting out and is well used. After running it until it was warmed up I noticed that it was pumping oil out of the dip stick.. What could be causing that ? building up of compression ? Thanks Guys.
Big Dean
12-07-2005 07:39:29
 Re: 50 ferguson in reply to Tony in Tenn, 12-06-2005 16:50:34
That problem is usually cause by either the crankcase breather tube stopped up, Bad rings, Diesel fuel in the oil or the worse thing would be the ring lands busted off one or more of the pistion. That is very common on the Perkins engines and especially so if it has ever had starting fluid used for starting it. They will start and run fairly well like that but have a lot of blow-by. maybe this will help you find your problem.
