model
geovair66
12-05-2005 09:01:31
hey all i was wondering where to find the model number on my tractor. the guy i bought it from said it is a model 65 from 1964 and i need a couple of parts.and want to be sure i get the correct ones any help would be appreciated
Big Dean
12-05-2005 14:19:44
 Re: model in reply to geovair66, 12-05-2005 09:01:31
The serial number tag is on the dash just under the tachometer. It may tell you what model it is some do and some don't if it does not then you should be able to tell by the serial number.
Aaron Ford
12-05-2005 11:31:37
Model number should accessible through the serial number. Look for the data plaque on the dash and compare to the list of serial numbers found on this site. You may need the serial number for parts as well. Some parts changed in the middle of the production run and are broken down via serial.
geovair66
12-05-2005 15:58:18
 Re: model in reply to Aaron Ford, 12-05-2005 11:31:37
no luck the body tag is gone the engine tag numbers are z-134 gas contiental serial 737205 does this help
geovair66
12-05-2005 20:20:36
 Re: model in reply to geovair66, 12-05-2005 15:58:18
does anyone know the mf p/n for the oil dipstick for the z134 engine or a replacement part number and where i can get one? thanks
Bob N.Y.
12-05-2005 18:36:02
Z-134 tells me that it is NOT a 65. The 65 gas had a G-176 engine. The Z-134 was used in the 35 and 50.
geovair66
12-05-2005 19:55:56
 Re: model in reply to Bob N.Y., 12-05-2005 18:36:02
that helps a bunch. thanks. now where can i find out which it is? i cant find a tag on the body anywhere thanks in advance
Bob N.Y.
12-06-2005 14:16:35
 Re: model in reply to geovair66, 12-05-2005 19:55:56
The front axle, steering arangement and sheet metal of a 35 resembles the older Fergusons.
Dan S (NY)
12-06-2005 14:10:06
third party image
The 35 and 50 have different front axels and sheetmetal. Here is a 50 from the Tractor Photes section of this site...
