Looking at a MF 165
Doug, Ontario
12-04-2005 15:55:35
third party image
I have been looking for a 50 plus hp tractor for the farm and there is a nice looking MF165 comming up at a local auction.
Can anyone tell me anyting about this tractor given the sn and the attached pictures?
s/n: SDW643011667
Thanks/Doug
Bill Brox
12-07-2005 12:58:45
 Re: Looking at a MF 165 in reply to Doug, Ontario, 12-04-2005 15:55:35
I have a MF 165, Perkins diesel, the AD4-203 engine. My cousin also... very good tractors. Excellent engine.
60 horsepower, long stroke, 3.6" bore, 5" stroke. Lots of good torque.
As mentioned earlier, the steering on these tractors are a trouble, mainly because no one wanted to go through the trouble of putting grease in the joints and bushings on the steering parts. This is a steering with many bushings, and many joints, so every slack ads up and give a lot. That is why lubrication on these ones are so important. I think my book says it has to be done every 10 hour, and I guess if the farmers did it every 100 hour it would have been the most. And then the tractors suffers and they get a bad reputation.
Except this, the MF 165 is the best of these tractors, because it has the strongest transmission and rear end compared to the horsepower. Hydraulics demand new oil and for you to clean the hyd. pump filter now and then. Or, to be specific, do it by the book.
In a few words: Massey Ferguson 165 - Excellent tractor.
Bill
mn.Chuck
12-05-2005 17:45:21
The s/n shows it to be built in 1966. That
late of s/n would most likely been actually
sold in 1967. The 165 is a great tractor.
One drawback would be a small output hyd.
pump if you are putting a loader on it.
The Continental engine is great but a little
hard to get some parts from MF but most avail
thru other sources. The drive train holds up
well due to the reduction boxes on the end
of the axle housings. Chuck.
CEB
12-07-2005 07:20:04
 Re: Looking at a MF 165 in reply to mn.Chuck, 12-05-2005 17:45:21
Chuck,
I have to correct you on one point. The diesel engine in his tractor is a perkins, not a continental engine. The continental engine was the gas engine in a 165.
mn.Chuck
12-08-2005 04:41:32
 Re: Looking at a MF 165 in reply to CEB, 12-07-2005 07:20:04
Thanks for the engine correction. The original
question didn't state the engine but the SDW in the s/n said it all. Thanks again. Chuck
Aaron Ford
12-04-2005 18:25:20
S= standard chassis D=diesel W=multipower tranny
phillip d
12-04-2005 17:42:53
hi Doug,we had a couple of 165's when i was a kid,the only complaint my dad had about them was that they wobbled on the road.he fixed it by tying tire tubes from the tie rod ends to the center of the tractor.if you get it tight,it will help.other than that,he liked them alot.
