Ferguson TE-20 PTO leak
Colin
05-31-2000 11:46:14
I have 1954 Ferguson TE-20 and the rear PTO has a real minor leak. WOuld this be easy to fix. It lokks like the outside bracket has four bolts and it is leaking on the seal behind this.
rod
05-31-2000 13:41:08
 Re: Ferguson TE-20 PTO leak in reply to Colin, 05-31-2000 11:46:14
Not really hard to fix park tractor facing down hill and block it good then remove shaft just take out bolts and pull it out I took mine to a Ford dealer they did seal and new bearing and installed it all for 35.00 then I put it back in. Now only have 49 other leaks to fix.
regards
rod
