Noise in transmission - MF175
L. Strack
12-03-2005 20:09:38
My MF 175makes a noise in transmission when Multi-Power is in High & clutch is disengaged.Stops when clutch is engaged. Was mowing with a 3 pt. 5 ft. mower when something made a loud noise.finished mowing,put MultiPower in High& noise like bad bearing or chipped tooth was evident.Need help pinpointing problem. Last fall using same mower,tranny popped & noise started, a tooth chipped out of pto drive gear.Replaced that spring 05, everything looked ok? 5ft.mower tomuch?
Thomas
12-04-2005 06:34:42
 Re: Noise in transmission - MF175 in reply to L. Strack, 12-03-2005 20:09:38
Have you got an overrun clutch on your mower? The momentum of a mower driving back up through the gearbox will do damage. Suggest you check this before spending money on transmission repair.
L. Strack
12-04-2005 18:16:25
 Re: Noise in transmission - MF175 in reply to Thomas, 12-04-2005 06:34:42
Good suggestion,willtry this to protect transmission. What is strange, I use same mower on MF135 & 2 other 32 HP tractors without over ride clutch, no damage to those. Any idea what can be making noise in tranny as gear & bearings turn in my 175?
L. Strack
01-22-2006 19:26:16
 Re: Noise in transmission - MF175 in reply to L. Strack, 12-04-2005 18:16:25
Now multi-power does not shift into high range. Pushing lever to high does nothing to change speed. Whats wrong with multi-power? There is a small filter canister in front of radiator to the top right side, with oil line attached, is this for multi-power oil?
