MF-35 Perkins Injectors
Dean
12-02-2005 01:04:24
Anyone know of a good and reasonable source for injectors for a MF-35 with Perkins engine?
Thanks, in advance.
Dean
machine works
12-04-2005 12:58:23
 Re: MF-35 Perkins Injectors in reply to Dean, 12-02-2005 01:04:24
Dean I have a set of 3 N.O.S. Perkins indirect injectors still in the MF dealer cans ,but they are the later style which has a larger spray orifice and uses higher pump pressure. I think some of the very late 35's used this setup. If you have your serial #'s ,I can check to see if they are compatible
Dean
12-07-2005 09:03:01
 Re: MF-35 Perkins Injectors in reply to machine works, 12-04-2005 12:58:23
Thanks for your offer and sorry for the delay in posting back.
Tractor is actually an FE-35, English version of MF-35 and engine is 3 cyl Perkins. Tractotr SN is M242158.
Let me know if injectors will fit.
Thanks.
Dean
machine works
12-08-2005 12:55:38
 Re: MF-35 Perkins Injectors in reply to Dean, 12-07-2005 09:03:01
Dean here"s the info on the injectors I have: the orifice size is.0157" and uses a lower pressure pump. According to my service manual, these were used on Perkins A3-152 engines s/n 1961449 and higher. They are marked with a small aluminum tag on the injector body as "DB" the correct pump to match these is CAV 3232788A the Perkins part # for these injectors is 35504. They were also used on the MF 204 workbull I am told let me know if these will work for you
Dean
12-08-2005 13:36:28
 Re: MF-35 Perkins Injectors in reply to machine works, 12-08-2005 12:55:38
Thanks, again. I will investigate to see if they will work. It may take me awhile.
Where are you and how much do you need for the injectors?
Dean
machine works
12-11-2005 12:21:01
 Re: MF-35 Perkins Injectors in reply to Dean, 12-08-2005 13:36:28
I am in middle Ga. as far as price i think I paid $100 for all three since they don't apply to my tractor configuration I will let them go for the same price I paid,.
Dean
12-11-2005 13:42:07
 Re: MF-35 Perkins Injectors in reply to machine works, 12-11-2005 12:21:01
Thanks again. I have not yet had the time to investigate whether or not they will work but will do so.
Dean
Dean
12-04-2005 13:34:36
Thanks for the follow-up. I will check the serial number tomorrow and post back.
Dean
jerrycpp
12-02-2005 08:50:17
I don't know about current prices, but many moons ago Spokane Diesel was an excellent place for CAV repairs and such. (509) 838-3556. It might be worth a call. At the Massey dealer we sent all our pumps and injectors to them for repair.
Dean
12-02-2005 13:08:56
 Re: MF-35 Perkins Injectors in reply to jerrycpp, 12-02-2005 08:50:17
Thanks, Jerry. I will give them a call.
Dean
