New to this board
22 Sam
11-29-2005 16:54:22
I have a real nice Massey 22, however,the the engine "hunts" quite a bit. It purrs like a kitten at idle speeds, but when I open it up, it just won't quit hunting. I've adjusted everything just like the manuals say, but to no avail. Should I suspect the carburetor first? P.S., I installed a manual choke recently.Could this have anything to do with worse hunting problem? Any good info appreciated.
msb
11-29-2005 19:54:26
 Re: New to this board in reply to 22 Sam, 11-29-2005 16:54:22
First thing to check is the play in the throttle shaft in the carburetor.There should be practically none. All the adjustment in the world won't stop the hunting you are talking about except at idle maybe.And welcome aboard,bob
22 Sam
11-30-2005 09:38:43
 Re: New to this board in reply to msb, 11-29-2005 19:54:26
Thanks for the info. I hadn't looked at the carb throttle plate yet, but will do so. I want to get everything running proper before the heavy snows come. I use the 22 for plowing.
