Worn out engine
ian orser
11-28-2005 07:43:06
My 1950 Massey Ferguson TEA20 engine is basically worn out. I have never taken it appart and re built but think it is time it will not start anymore when it is cold. if I pull it around the yard it will fire right up. And runs OK it has always had a lot of blow by, especially when working, but it keeps chugging along. What is best to do I was thinking Valves, rings, maybe sleeves not sure how to do that but probably need to buy a kit with everything. Maybe even pistons and bearings too. Did not want to spend a huge amount on machine shop work but want to keep my tractor running. Any recomendations on where to get parts and or how far to go with a re build???
Logan in S.E. Texas
11-28-2005 16:50:17
 Re: Worn out engine in reply to ian orser, 11-28-2005 07:43:06
I agree with the others, if you are going to the trouble and work of pulling and tearing down engine, you might as well do everthing that needs doing. As far as spending a lot of $$$. Think about it this way, it is a 1950 model and never been rebuilt? If you do it right the first time, it should last another 50+ years.
Jason(PA)
11-28-2005 15:58:37
Go threw it 100% and you won't have to ever worry about it again. It can be fun rebuilding engines,but its not fun taking them apart again after being cheap or in a hurry. While you go threw the work of taking it apart do it right! Have fun!!
Jerry/MT
11-28-2005 12:31:53
If you have to pull it to start it, your valves may be adjusted too tight. I agree with the other writer. If the tractor is plum wore out, you need to rebuild it right. The more you use it while it's worn, the more machine shop work you'll have to do. Anything less than rebuilding will cost more in the long run and you'll never know if it's gonna' run when you need it. Just my opinion.
mf35jim
11-28-2005 09:00:27
No easy way around a full rebuild and doing it correct. Often anything else cost more in the long run. Purchased a bunch of part from our host and things are good so far. As far as machine shops, there usually is one really great machine shop that specializes in tractor stuff. The trick is to find that shop in your area.
