where the serial?
Olivier
11-28-2005 06:29:14
Hey, my boss just buy a Massey-Harris tractor. We are unable to fin the serial. the only serial that we find is : on top of the transmission close to the shifter-7407A. One we find is on the side of the transmission housing (Clutch pedal side)-62044. And the last one we find is under the tractor and it a production date 44-10-6. We made research and find nothing.
Olivier
11-29-2005 06:42:40
 Find it in reply to Olivier, 11-28-2005 06:29:14
Thank to you all, we find it did some scapping and it a 1944 101 junior standard.
Olivier
11-28-2005 12:40:27
 got picture if it could help in reply to Olivier, 11-28-2005 06:29:14
it a 4 cylinder flat head, and it a standard front 4 wheel. Got pictures if it could help
Alberta Mike
11-29-2005 06:30:57
 Re: got picture if it could help in reply to Olivier, 11-28-2005 12:40:27
A four cylinder flathead could be a MH 101 or 102 Junior, or maybe a 81,82,20 or 22 from that series. Then later, maybe a MH 30. Or the series that included the Colt, Pacer, Mustang, etc. Does it have a cast iron front tub or a channel iron front frame? Does it have (or did it once have) hinged sidepanels? These things would help. Scrape for the serial number as Dave has suggested, sometimes those numbers aren't stamped in too deep there on the upper machined surface of the tranny/differential case.
lee medley
12-02-2005 20:30:49
 Re: got picture if it could help in reply to Alberta Mike, 11-29-2005 06:30:57
oliver; i have a supposed massey with a very wide ft end no numbers and so far no serial/model no.
it has a 4 cyl flathead and no #, trying to identify so that i can try to rebuild, it has pto, and hydraulics, any help expected. thx lee
Dave_Id
11-28-2005 10:16:38
 Re: where the serial? in reply to Olivier, 11-28-2005 06:29:14
Give us some hints, like who made the engine, is it a 4 cylinder, 6cyl, row crop, big tractor, little??? Most of the ser. numbers are stamped on the trans case under the seat, by your left foot. You may need to do some scraping of paint. Most serial numbers are six digits along with prefix letters. The 62xxx don't correspond with any ser. numbers in the Data Book.
