Massey Ferguson loader
valiant696
11-28-2005 06:25:50
I have a MF 65 that I would like to put a loader on. I have found on from a MF 35. Does anyone know if the frame dimensions are the same to where this will bolt right on? The loader has a hyd. pump that mounts to the front of the crankshaft also. I wonder if anyone has this type of setup on a MF 65?
Thanks,
Joel
mn.Chuck
11-28-2005 19:06:16
 Re: Massey Ferguson loader in reply to valiant696, 11-28-2005 06:25:50
Depends on the loader brand. You would
definitely need to do some mods. Front
ends are completely different. Also the
Front pump does not work out well on a 65
If you watch your cast iron steering arm
it crosses in front of the hole that the
the shaft goes thru so you can't turn one
way more than a tiny bit. Also would need
different C/shaft pulley with the tapped
holes unless it has already been changed.
MF had kit years ago to change those steer.
arms but $$$$ and avail?
