MF-135 Timing Mark
Donald Van Drei
11-27-2005 17:08:34
Trying to set the timing and can't find the timing mark????
Big Dean
11-28-2005 08:23:56
 Re: MF-135 Timing Mark in reply to Donald Van Drei, 11-27-2005 17:08:34
The timing marks are on the fly wheel the Continental engine has a small round hole in the transmission mounting flange on the left side. It may still have the chrome plug in the hole. The Perkins engines have a rectangular hole in about the same place on the transmission mounting flange. It may have still have the rubber plug in the hole. The fly wheel can be bolted on the Perkins engines in 6 different positions I have found several that the times marks were not where they should be because the flywheel had been bolted on in the wrong position. You usually have to clean off the flywheel to find the marks on all the engines used If I can be of further help email me
