mf 85 3 point
clint hyde
11-22-2005 17:15:59
i have a mf 85 have searched throught here but cant find an answer. i have to use the aux. hydraulic lever (left on a two spool) to be able to use the 3 point positioning levers. anyone have aany info on this prob would be greatly app.
thanks clint
kingtnt
12-02-2005 08:41:09
 Re: mf 85 3 point in reply to clint hyde, 11-22-2005 17:15:59
I have an owners manual for the aux. hydraulic system for the MF-85. It cover the correct use of the system and I think but not sure right now that it has a trouble shooting section as well. I can copy it and send you a copy for $10. Let me know if you would like it. If so, let me know at my e-mail address: [email protected]
just dan
11-25-2005 17:08:18
Not exactly sure if your tractor set up is the same or not or even if this will help, but my father has a super 90 and there is a small metal wheel just under the hydraulic levers that can be turned, when screwed all the way in or out ( I forget ) you can use the hydraulic lever to lift the 3 point arms and in the other position ( full in or out) you can lift the three point arms with the manual slide lever. Hope this helps
Allan/NCA
11-23-2005 18:02:03
I had a MF35 that had a 3 spoole valve with one for the 3 point and the other two for the loader. It was dealer installed with the 3pt control wired open. I replaced the unit with a different valve that lets me use the orignal 3pt controls plus the aux valves. The system works ok and most industrial tractors now use control valves in place of the normal 3pt controls.
