MH 30 Oil Pressure?
Jason(PA)
11-20-2005 17:09:11
My neighbor is fixing up a ol 30 Massey and he was putting it back together and noticed the oil pressure was at "0" We cracked a few of the oil line fittings and oil is coming out of them. Maybe just the guage,but we are wondering about the big nut on the side of the engine(near carb) that adjust oil pressure or something like that? Can anyone shed some light on this area? Thanks!
Rod in Smiths Falls, ON,
11-21-2005 14:33:31
 Re: MH 30 Oil Pressure? in reply to Jason(PA), 11-20-2005 17:09:11
The manual says not to run the engine if the oil pressure does not come up.
My 30 starts at about 25 lb with 15W40, then gradually eases down to about 8 lb at low speeds when it is hot, rising to about 10 at idle and more than that at PTO speeds. I've never seen it read lower than 7 lb when hot and running slowly.
It generally reads about l2-15 pounds when hot and operating at normal speeds.
I'm pretty sure the manual has nothing to say about adjusting the oil pressure.
Good luck,
Rod
