MF TO 35 Tractor
Mark Thompson
11-20-2005 15:59:55
Just bought me a TO 35 the other day. My very first tractor. It has live Pto and 2 stage clutch. I have a few questions about operation. Where you turn the tractor on, the switch can also turn to "1-L" and "L" of which I assume is something to do with the headlights which i have to fix. What is the difference between the two? 2nd question: What application is ground speed pto used for? Lastly, What type of moter oil should I use and can I change to synthetic oils for an older engine? Thanks
mn.Chuck
11-22-2005 17:29:27
 Re: MF TO 35 Tractor in reply to Mark Thompson, 11-20-2005 15:59:55
Some already answered. The ground PTO works
best with a 3 pt rake. You can throttle the
tractor down and put in a higher gear to save
fuel. Some MF mowers have a sheave selection
so you can do the same thing. I used a three
point cone wood splitter and wedged it. I was
glad for the ground PTO. Put tractor in reverse
and reverse the Pto splitter right out. You may
likely never use it. Do not bother using the
synthetic oil. Chuck
RegoR
11-22-2005 06:11:59
Hi Mark;
I=ignition & L=lights.
The swithch allows for combinations of the two.
There have been lots of discussions regarding oil used in these old tractors on this and related forums within YT and elsewhere. Try a search here and see all the info you can amass.
Good luck and have fun!
RogeR
Rod in Smiths Falls, ON,
11-21-2005 14:52:34
You didn't say if it's gas or diesel. For my diesel 35 last year the dealer recommended their brand 10W30 for winter and 15W40 for summer. I'd save my money on the synthetics: far better to change the oil regularly and get the grit out than to go to some long-life crud accumulator. Just my 2c here, though.
Ground speed PTO: short answer? Don't use it.
longer answer? It adjusts pto revs to tire revolutions, and can be used only for non-ground-engaging implements such as seeders and tedders. Beware. If you back up with the pto on it will turn the implement backwards, most likely with catastrophic results. I have heard of innovative people freeing a stuck post hole digger by jacking up one back wheel on a 35, then running ground-speed pto in reverse to back it out.
And in answer to the question you haven't asked yet: the transmission holds a WHOLE LOT of fluid. Don't try to use your car's oil change pan (as I did) to catch it. Also, don't pour two five-gallon pails of fluid into the transmission until you figure out the difference between Imperial gallons, U.S. gallons, and litres.
All right, I have hazed the newbie enough. Here are the key capacities listed in my MF35 Diesel owner's manual (1961):
Fuel tank: 8.5 Imp, 10.2 U.S. gallons
Cooling System: 9 Imp. quarts, 10.8 U.S. quarts
Crankcase: 5.25 Imp. Quarts, 6.3 U.S. quarts
(Add one extra pint when filter element is changed.)
Transmission, Differential and Hydraulic System:
6.6 Imp. gallons, 8.25 U.S. gallons
Hope you have a great time with your new toy.
Rod
Mark Thompson
11-21-2005 17:45:16
 Re: MF TO 35 Tractor in reply to Rod in Smiths Falls, ON, , 11-21-2005 14:52:34
Thanks Rod for your response. My TO 35 is a gaser with the 4cyl continental. Can you tell me what the two different(1-L,&L) light switch settings mean?
11-21-2005 19:20:23
 Re: MF TO 35 Tractor in reply to Mark Thompson, 11-21-2005 17:45:16
Probably one is for headlights, and the other for headlights plus rear-facing lights for things like ploughing, snow-blowing, etc.
Actually, what all of the lights are for is bashing your elbows when you least expect it. Be careful with the wiring if you are planning to use tire chains. They tend to shred everything.
11-21-2005 19:17:45
Mark Thompson
11-22-2005 15:35:32
 Re: MF TO 35 Tractor in reply to Rod in Smiths Falls, ON, , 11-21-2005 19:17:45
I found some information about the lighting. The "I L" stands for ignition and lights.The "L" only stands for lights only so that you bypass the points. That way you don't burn them up when the engine is not running. Made sense to me. Thanks
