injector pumps
okiejones
11-19-2005 08:13:52
rebuilt a 59 to 35 with a 23c new crank and bearings, pistons sleves and valves runs good smokes white a little, it doesnt seem to have the power it did even with a cracked piston. if i advance or retard the injector pump timing will that give me more power? if so what is the correct way to do this.
thanks for any advice
Thomas
11-20-2005 07:23:30
 Re: injector pumps in reply to okiejones, 11-19-2005 08:13:52
Did you renew the timing chain and tensionner, and take up the backlash through the back of the pump drive before timing? I've not had much trouble with these engines, lock the flywheel with a 1/4" drill bit, take up the slack with a big screwdriver and adjust the pump by looking inside it's inspection plate. Also clean the last chance filter on the pump inlet (rear).
