massey 255 ?s
mike j
11-18-2005 18:15:50
Anyone tell me if a 255 would have a 540 and 1000 rpm pto. thanks mike
Don-Wi
11-18-2005 19:27:56
 Re: massey 255 ?s in reply to mike j, 11-18-2005 18:15:50
A tractor of that size, I don't think would have 1000 pto. The 285's are capable of 1000 rpm, but you need to find a shaft for it.(close to impossible) What are you looking to run? Disc mower? If its of any size(8-10 ft.), you'll need atleast 80 HP to run one, like say, a 285.
Donovan from Wisconsin
mike j
11-19-2005 11:25:21
 Re: massey 255 ?s in reply to Don-Wi, 11-18-2005 19:27:56
no don i don't own this tractor it isnt big enough I bought a sawmill and the guy said that he was running it with this tractor and that he was running it at 1100 rpm on the pto I was having trouble believing this as most circles DON't turn that fast . thanks mike
Don-Wi
11-19-2005 15:06:20
 Re: massey 255 ?s in reply to mike j, 11-19-2005 11:25:21
You may be able to turn the gear box around(if there is one), like some other machines are capable of doing and then use 540 and be in the clear. I agree a 255 might be too small for a saw mill, but then again I have seen some smaller ones doing the job. Where are you located? I may be looking to have some wood cut for a hay rack some time....
mn.Chuckc
11-22-2005 17:35:27
 Re: massey 255 ?s in reply to Don-Wi, 11-19-2005 15:06:20
540 only.
mike j
11-19-2005 18:47:32
Well i think transportation could be a killer as im in southeren oregon. yea i agree it aint really big enough for the mill but i got that worked out i,ve got a d8800 cat diesel engine to run it but tryin to figure out the speed for the blade 100 horse should do it though. later mike
