MF30 Hydraulic valve
Dee Yawn
11-16-2005 17:28:51
I recently bought a MF30 industrial with loader and backhoe. The loader valve will allow the loader to leak down and also the bucket curl will not hold . The cylinders have been recently repacked. The valve is made by Parker Hannafin so I contacted them and they said it has been discontinued, and they offer no replacement.I questioned them about replacing it with one of the two spool loader valves offered by Prince hydraulics or Cross and they said these would not work because the original has a return port on the mounting flange of the valve it returns right into the reservior and also is regenerative. The prince valve is power beyond capable and has a float on one spool but it is not regenerative, and does not have the extra Return port. I can deal with the plumbing issues and manufacturing a mounting bracket I just want to make sure the replacement valve will work properly and also that the power beyond conversion will allow the backhoe to work also thanks
Big Dean
11-16-2005 20:48:45
 Re: MF30 Hydraulic valve in reply to Dee Yawn, 11-16-2005 17:28:51
I have installed a Cross two spool valve with a built in relief valve on both the MF32 and MF34 loaders that are used on the MF30. The only thing I am not sure of is if the power beyond on those valves has enough volume to operate he the backhoe if not you can run the return line from the loader valve to the backhoe and use the backhoe return for both valves. Email me if you need more Information on this.
