Used transmission for MF 180 tractor
Thomas Carr
11-16-2005 15:11:19
I have a MF 180 tractor with a bad multi power transmission and would like to replace it with a standard 6 or 8 speed transmission. I would like to know the range of tractors models that the transmission would interchange with the MF 180. I would appreciate any info on this topic.
Thanks Thomas
Big Dean
11-16-2005 20:32:03
 Re: Used transmission for MF 180 tractor in reply to Thomas Carr, 11-16-2005 15:11:19
It depends on how old it is the early models had a 10 spline three point pump with it the 6 or 8 speed transmission from an early MF135, MF150, MF165, MF175 MF180 or an MF1080 will bolt right in place of the multipower transmission. The Late model of those tractor and the MF200 series AG tractor starting with the MF245 up through the MF1085 the three point pump on them has 21 spline if that is what you have then any of those tractors with the 21 spline pump will work.
Able
11-17-2005 04:38:54
 Re: Used transmission for MF 180 tractor in reply to Big Dean, 11-16-2005 20:32:03
big dean, so you are saying a 180 uses the same transmission as a 135?
Big Dean
11-17-2005 15:26:28
 Re: Used transmission for MF 180 tractor in reply to Able, 11-17-2005 04:38:54
I am saying it will fit right in where the multipower transmission came out. Some of the gear ratio may be a little different and some of the cases may be a little heavier but the one from an MF135 will work. I believe you have to use the top from the MF180. Big Dean
