Ft. lbs. formula
Mark Roth
05-30-2000 17:00:20
I have a Massey Ferguson 65 gas, the motor is 176 cubic inch and the valve compression is at 7.1 to 1. If I did a compression test on each cylinder what should my ft. lbs. be. Any help would be appreciated.
twopop
05-30-2000 17:32:24
 Re: ft. lbs. formula in reply to Mark Roth, 05-30-2000 17:00:20
Good compression should be about 120 psi,anywhere from 90 to 120 is acceptable but most important is that the cylinders are within 10 percent of the highest reading.compression is measured in psi not ft lbs. also compression will change depending on elevation above sea level
