Follow up question for wheel weights
Robin Mach
11-14-2005 12:00:45
For those of you running a 44 or similar sized tractor, roughly how much weight would you recommend adding to the rear wheels for general utility work? I use the tractor for general around the house utility, not for ag use. This is a 1952 44RC with 13.6x38 rears. Right now the back end is a hodge podge with a concrete weight on one side on a dry tire, no weight on a fluid filled tire on the other side.
Thanks all,
Robin
Midwesterner
11-14-2005 17:04:31
 Re: Follow up question for wheel weights in reply to Robin Mach, 11-14-2005 12:00:45
Why bother with any extra weights or fluid at all if you're just cutting grass, etc. Heavy work w/loader or field diggers is another matter. Save fuel carrying less weight.
