PTO speed on MF1105
KYfarm
11-14-2005 09:29:46
Does anyone know the PTO speeds on an 1105. Tractor data has it as 1000 only. I'm considering buying an 1105 but have only 540 rpm equipment.
dsm
11-14-2005 17:09:49
 Re: PTO speed on MF1105 in reply to KYfarm, 11-14-2005 09:29:46
1105 has both 540 and 1000 you can change the pto stub
phillip d
11-14-2005 17:09:36
Hi KYfarm,look at the pto shaft to see what it is.If it has(i never counted to see for sure) eight or maby ten slots then it is 540.We had a 1085, made during the same period as the 1105's and it had 4 bolts you removed and slid off the pto housing&shaft to replace it with the other one.If the 1105 is the same(likeky is) and it does have the fine spline shaft,then all you need to do to get 540 is replace the housing and shaft with the other one,if the 540 doesn't come with the tractor then one should be avail at a parts yard.Shifting the shaft is as easy as using a 3/4 socket and 2 minutes of time.Hope this is of some help.
