Probably a very silly question about wheel weights
Robin Mach
11-14-2005 07:33:22
I know this is probably a silly question, but is there any difference as far as operating a tractor whether you get your rear wheel weight from fluid or from bolt on weights? Is there some advantage to one over the other, besides the fact that if/when the fluid starts leaking it chews the rim up?
Thanks all.
Robin
old
11-14-2005 10:48:13
 Re: Probably a very silly question about wheel wei in reply to Robin Mach, 11-14-2005 07:33:22
I have found over the years that fluid in the tires seem to work better then weights. Only thing I can figure is it puts the weight on the tire where it hits the ground and has not bounce because of air in the tire as you get with weights.
jf
11-14-2005 08:11:59
As far as operating goes, there is no difference. Weight is weight. But, with the wheel weights, an operator has to make sure they stay tight on the rim. Loosing one in the field is a pain. And tire repair is cheaper because the tire company does not have to pump the fluid out to fix the tire. There are probally others, but this is talking from experience.
