Mhf 202 differnce from Mf202
KC Casey
11-13-2005 10:01:23
Dont know if this makes any differnce the complete serial# is jgf-300175. Not sure how to post picture. Defently gas motor believe it to be continental 134z has a davis loader looks like it could of had a back hoe plumbing and fititngs there . Im new to these Massey Fergusons. when i firt seen it i thought it was a Ford when i figured out it wasnt i thouht i would give a Massey Ferguson a try. I also have a 1000 and 2000 Ford Hoping this isnt a odd ball.
Christos
11-13-2005 20:52:24
 Re: Mhf 202 differnce from Mf202 in reply to KC Casey, 11-13-2005 10:01:23
Ok, I think this was explained before, and not to be a jerk, but here goes. As I am sure you know, in 1953 the year after the Ford v Ferguson lawsuit was over, the Fergie Co. merged with Massey-Harris Ltd of Canada, so Massey-Harris-Ferguson was formed. In 1959 the company became Massey-Ferguson Ltd/Co. So, your M-H-F stands for the first corprate name of the merged companies. That tractor isn't an oddball - those from what I undestand they were quite popular and the Z134 engine block was used on the Fergie 35, MF 35, and the MF 135 Special. How does it compare to the Ford 1000 and 2000? Not sure, but I do know that the Ford 3000 is a lot like my MF 135 deluxe in terms of its capablities. Understand though, the MHF/MF 202 is an industrial tractor and was supposedly to be used in a different capasity than a traditional AG tractor, like more heavy duty stuff, road repair, mowing, and whatever else could be cooked up. I belive they were supplanted by the MF 40 which lasted until the 135 production run ended in 1975 - they shared the basic sheet metal as the 135.
I apologize if I come across as redundant, however I do hope this helps you out.
Christos
GaryF
11-13-2005 18:53:50
It won't be an oddball. I think some early 202's had a hood like a North American MF35. Most models had a cast upper housing and a grille with round holes in it. Does yours have power steering with a non-adjustable front axle? Have you tried a search in the Tractor Photos?
Gary
Kc casey
11-14-2005 15:07:07
 Re: Mhf 202 differnce from Mf202 in reply to GaryF, 11-13-2005 18:53:50
Yes my mhf 202 has non adjustable front axel and power steering sheet metal hood front grille look like mf 35. I will check the picture gallery. thanks for the information the more i work on this tractor the more i like it. I probably will give it a complete restoration.
parts man
11-14-2005 19:45:54
 Re: Mhf 202 differnce from Mf202 in reply to Kc casey, 11-14-2005 15:07:07
A 202 is basically an industrial 35.
GaryF
11-15-2005 02:16:32
 Re: Mhf 202 differnce from Mf202 in reply to parts man, 11-14-2005 19:45:54
Thats right. Asside from the front axle and difference in colour.
I have also seen a MF35 Utility, Non adjustable front axle,MF35 hood, MF 65 (planetary)rear axle it was a diesel and yellow
