4WD model with driveline problems?
David M
11-11-2005 06:36:24
I've seen the same parts come into our shop over the years and I was wondering if someone knows what model they come from. I'm sure it's from a Massey 4wd maybe built in the '70's.
These parts include a drive pulley for the hydraulic pump mounted on a tapered hub on the transmission input shaft. I believe the splined shaft is driven with some kind of rubber-mounted spool.
Is that enough information for an ID of the model? Can you give me a better idea of the parts layout? A picture would be great. Thanks
MF rules
11-11-2005 23:42:59
 Re: 4WD model with driveline problems? in reply to David M, 11-11-2005 06:36:24
I believe the model your talking about is a MF 1805 4wd tractor..... .not sure but have heard of some issues with a driveshaft that drives belts that turn pumps somewhere under the tractor????..... maybe someone else can be more specific..... rumors I've heard is its a bugger to change the belts???? I have a MF 4900 4wd tractor and it has no such thing you mentioned above. Hope this helps.
