Massey 135 hydraulic query
Dave Picton-Kin
11-07-2005 01:57:27
I recently replaced my original Massey 135 hydraulics controller with a two-position lever off the pump- position one allows two sets of hydraulic quick release couplers to operate. Position 2 allows the 3 pt linkage arms to operate. The hydraulics only operate if the 3 point linkage is at the full down position. If I try to use the hydraulics while the linkage arms are anywhere above full down, there is no hydraulic flow through to the couplkers.
Is this a fault, or a 'standard feature'? Any ideas how I can set the linkage arms to a raised position, then switch to using the hydraulics while leaving the linkage set as required?
Big Dean
11-07-2005 10:34:10
 Re: Massey 135 hydraulic query in reply to Dave Picton-King, 11-07-2005 01:57:27
Hi Dave After you select to the remote hydraulics move the Position control lever to constant pumping to operate the remote hydraulics. You want to be sure to take it out of constant pumping before you switch to the three point. If I can answer more questions on that valve email me
