hydraulics massey 165
sam un ont
11-03-2005 17:32:44
recently got a 165 that for wharever reason the lift arm lingage and piston had been removed . i located complete lift arm assembly and had the pump rebuilt and reinstalled. Now for the problem, the draft control will raise or lower the arms but the pressure control seems to have no effect as it will not raise or lower the arms with the draft in the up position. when looking through the side platei see the draft control moving the pump lever but no movementwith the position control. any ideas?
sam un onts
11-06-2005 06:05:44
 Re: hydraulics massey 165 in reply to sam un ont, 11-03-2005 17:32:44
checking further i seem to have what can only be discribed as an elongated holein one of the arms where it meets the vertical leaver. is this normal and from what i read there should be a spring somewhere on this leaver. I seem to be able to set the draft control but ther is no pressure on the leaver when i try to set the pressure control. I am sure the answer is staring me right in the face but i can not see it .HELP
Big Dean
11-03-2005 20:13:36
You have a piece of linkage out of place it happens a lot when you install the quadrant controls in the linkage cams. It will also pop out of place if the implement hits something solid and especially if it hits something while going backwards. I have a picture that shows how it is supposed to go. If you want the picture send me an email address
sam un ont
11-04-2005 10:06:41
 Re: hydraulics massey 165 in reply to Big Dean, 11-03-2005 20:13:36
pulled the lift cover off and found thar the roller for the position control was not ther. found another quadrant control ,put it in and i seem to have movement now,but with no diagrms etc. i am only assuming things are in right, but the instructions for pressure and draft controlsare causing problems.
