Getting Power Steering to work on MH333
G.E. Larson
11-02-2005 18:00:12
I am trying to convert my 333D to factory power steering. Installed a factory unit, an original flow divider, a wide front from a factory power steering tractor. The 3 point hitch works fine, but am getting no help on the steering. The only thing that I hav'nt replaced is the little canister beside the hydraulic reservoir
Harris Guy
11-03-2005 10:08:21
 Re: Getting Power Steering to work on MH333 in reply to G.E. Larson, 11-02-2005 18:00:12
In your supply of MH PS parts, do you have a brass
elbow that would replace the cap on the relief valve, of the hydraulic filter? I believe this
plumbs back into the factory MH PS assembly, via
a brass tube. You may have some air lock issue
impeding function. I recall removing similar type
small parts on a former PS Triple, in the past.
Good luck.
G.E. Larson
11-03-2005 17:10:28
 Re: Getting Power Steering to work on MH333 in reply to Harris Guy, 11-03-2005 10:08:21
I drilled a hole in the cap and plumbed the brass tube into it.
