I am considering buying a Massey Ferguson Industrial tractor. I am told that it is an MF403 which is the industrial version of the MF185.It supposedly has the internals of the 3PT hitch including the actuator arms (under the seat) and the control levers. It also supposedly has the PTO plumbed to (but not out) the back. These pieces were apparently left off to make room for the backhoe. I tried to lookup this tractor on our local AGCO dealer's CDROM system but found no trace of 403, and hardly any of 185. The MF320 backhoe attachment was in there, but it appears to be in good shape. I called around the area's tractor wreckers, and none of them heard of MF403 and MF185's are super-scarce. I'd like to be able to toss off the backhoe and do some 3PTH work, and maybe even some baling... This machine will probably be fine, but I'm a little leery of something that appears to have zero used parts available. Apparently Massey dealer parts are pretty pricey. Can I get used/jobber 3PTH arms and links for this thing ? Can I get the PTO shaft exit bearing/guard ? Should I just forget it and stick with something more common ? Should I not be such a chickenshit and just buy it for the heavy duty loader, the backhoe, the Fwd/Rev shuttle ? yours, kurt klingbeil
