hope for a response from someone
wahoo
10-31-2005 10:39:26
posted steering problems ? for 235 on 10-27, please help!
DavidP, South Wales
10-31-2005 14:04:06
 Re: hope for a response from someone in reply to wahoo, 10-31-2005 10:39:26
Hi,
I assume it's a MF but need more info on the type of steering box, whether it has one drop arm or two. If you can describe the steering system I will try and help not familiar with that model in UK unless it is a 2135.
Regards
David
wahoo
11-02-2005 07:10:21
 Re: hope for a response from someone in reply to DavidP, South Wales, 10-31-2005 14:04:06
Thanks David P.,
It's a 235 serial#9a22I324. Gear box has two drop arms, is stamped LAPAZ 36/1 with #s 30 00 01 414 stamped in a circle around the casting. Both pitman arms shot, sleeve busted on one side. Steering nut on bottom of steering shaft ok but have heard of a recall on this part. Tried to order parts but must know if tractor is manufactured in UK. Have been told will just tear up again unless I remove front end loader model #100 serial #1140-104834. Thanks Again
jrsn
11-02-2005 19:47:55
 Re: hope for a response from someone in reply to wahoo, 11-02-2005 07:10:21
Link
According to the serial NO"s at left you may have a 1975 US made 235. The Bareco site has both US and UK parts listed. Ray-s
