1130 M F tractor
John Walker
10-29-2005 07:44:44
The turbo charger is leaking a little oil while tractor is idleing. Any cure for this.
jogl
10-30-2005 03:58:37
 Re: 1130 M F tractor in reply to John Walker, 10-29-2005 07:44:44
Where abouts on the turbo is the oil coming from? If its comming out of the pressure side boot thats not good, will need to repair turbo. You may get lucky and its just a leaky oil line.
If you take an air line off of the turbo carefully check for play in the turbine shaft. Shouldn"t be much at all. Also check for oil on impeller blades.
Need to do a little digging. Good luck.
