pacer and y-91
spitz
10-28-2005 12:39:28
Just wondering if anyone knew of any other specific forklift or generator models came with the same engine as the pacer. (continental y-91) It would make my parts search a little easier. Thanks.
TJT
11-01-2005 18:47:19
 Re: pacer and y-91 in reply to spitz, 10-28-2005 12:39:28
Oh, almost forgot, Miller Electric had a welder called, I think, a Big 20 with a Y-112 that would probably work also, only problem with that is the fixed speed governor and carb, if you had the governor and carb from the orig. Pacer engine (Y-91) you could undoubtly make that engine work also. Tom
TJT
11-01-2005 18:42:15
Probably the best swap for the Pacer that would be the easiest is a Y-112 engine from a American Lincoln floor scrubber or a Tennant Scrubber, both very close to the same configuration, Tennant had a longer oil fill tube and a PCV system. Some small Hysters had a rather close spec. but with a down draft carb. (use the pacer manifold.) Clark lift trucks with "Y" engines were way different.
