PTO on 444D
GeorgeY
10-27-2005 21:19:04
There is no PTO installed on the 444D model in my possession.It is possible to install either a PTO or LivePTO onto this model? What parts are needed for the installation?And what is the difference between PTO and LivePTO?
Thanks.
Harris Guy
10-29-2005 11:26:07
 Re: PTO on 444D in reply to GeorgeY, 10-27-2005 21:19:04
If you are certain it is a 444, not just wrong
decals, your tractor would have the lowered PTO
housing, above the draw bar. These have more parts
to achieve PTO. An upper shaft runs from the front
of the transmission case, with a gear on the rear,
and bearing. A second gear is below, then a third, which is attached to the PTO shaft. MH did
not complete the R & D plans, to offer independent(full Live PTO), like Oliver had. Harry Ferguson,
on the MHF Board in 1953, baulked at any budget for the MH tractor division. MH had offered an
over-ride PTO hand clutch, beginning with the 1950
44 Diesel. This option remained the sole link to
live-power, through 1957 production. Attempting to install the live clutch today, reqiures a MH
hobby mechanic, or an I & T manual(teardown, pull
a bevel gear-2 days labor). The live clutch assembly includes double disc brakes, but the clutches are often worn, back shop drilled,bolted,
due to slippage under hard pulling. Unless your 444D is a Standard(30" rear tires), surprised it
has no PTO.
