1010 Motor problems
mf1010
10-27-2005 15:40:33
My 1010 diesel tightened up and will not start, though it turns slowly and blows black smoke. Mechanics give differing opinions, so I am looking at worst case scenario. Who manufacture the 1010? Are parts available? I am frustrated, and since the compact tractor market in Iowa, can you believe it, is mighty small. Not much epertise around here
mf1010
marlowe
10-27-2005 18:54:14
 Re: 1010 Motor problems in reply to mf1010, 10-27-2005 15:40:33
what do you mean it tightened up? did it over heat? run low on oil?. might be some thing other then the engine. hyd. over load bad pump or some thing stuck. seen a bad power steering pump stop a engine. if it was running good and just stop ed i would start looking for other things
mowr
10-27-2005 18:28:47
Made in Japan by Toyosha Hinomoto. If your MF dealer can't get parts, you might check with homesteadtractor.com for new or used parts or a complete used engine.
GRJ
10-28-2005 16:11:40
 Re: 1010 Motor problems in reply to mowr, 10-27-2005 18:28:47
Hey, why don't you hit your enter button a few more times. Not sure what you said. Please repeat,repeat,repeat,repeat.
mowr
10-29-2005 18:32:05
 Re: 1010 Motor problems in reply to GRJ, 10-28-2005 16:11:40
Thanks for bringing a smile. When I tried to post, I couldn't get the browser (or the site) to go to the page that notifies that the message has gone through. Finally, it came up and I checked to make sure it cleared, only to see that it had gone through every time. Huh? Duh? Howzattagan? If you can tell me how to delete the extras, (in case that ever happens again), I'll appreciate it.
2x4
10-29-2005 23:18:11
 Re: 1010 Motor problems in reply to mowr, 10-29-2005 18:32:05
you cant delete the extras, only Kim can.
2x4
10-28-2005 19:53:01
why don"t you hit the "exterminate" button & do the world a favor?
mowr
10-27-2005 18:28:06
mowr
10-27-2005 18:26:52
