Steering box question for a 44
redbastrd
10-27-2005 03:20:01
I took off my steering box last night. I want to replace the shaft that the worm gear is on because someone welded it to the u-joint. Can you seperate the worm gear from the shaft? Or is this one piece?
Harris Guy
10-27-2005 14:45:51
 Re: Steering box question for a 44 in reply to redbastrd, 10-27-2005 03:20:01
The worm gear is pressed onto the shaft, which is
splined. If your 44 is a NFE, this is a common part to find, used, since many models(22,30,33,44,
44 Special) have a similar steering assembly. If
the weld was not professional, perhaps easier to remove the weld bead with a power chisel. Good Luck
