MF 255vsMf 231
Larry-In-
10-26-2005 09:21:09
Any opinions on a MF 255 vs a MF 231. Will be used with a 6ft bush hog and occasional loader work. Thank You for any input.
GaryF
10-28-2005 08:31:19
 Re: MF 255vsMf 231 in reply to Larry-In-, 10-26-2005 09:21:09
MF255 has 4cyl diesel early 204ci late 236ci in addition to hydrostatic steering it has a planetary rear axle and wet disc brakes would be a much better loader tractor with more power. Mf231 is newer and a bit smaller(3 cyl) and lighter duty (but still very useful) I would prefer the late 255 early was a shaker.
MF#1
10-26-2005 18:35:09
Also, the 231 is a newer model tractor than the 255. may be harder to find a cream puff 255. I agree with Buford, the 255 is better at a lot of things. Without a loader the 231 "should" do all you want. The only "weak" part, IMHO, in the 231 is the front axle and power steering cylinder. The engine is nearly bullet-proof.
buford
10-26-2005 17:03:26
the big difference between these two tractors is the 255 is a better all around tractor better brakes ,hyd,steering ,clutch a smoother handling tractor far superior in all ways. the 231 in my opinion is a dressed up mf 35 with flat top fenders I think about the same about the 261 it a dressed up mf 65
