1080 Massey hard to shift out of gear
Curtis H
10-25-2005 12:24:38
I have a 1080 and on an incline I can not shift the trans. out of gear. when on level ground it will shift fine. I have adjusted the clutch already, does anyone have any ideas.
Thanks Curtis
Laurence
10-26-2005 18:37:14
 Re: 1080 Massey hard to shift out of gear in reply to Curtis H, 10-25-2005 12:24:38
I have a MF240 that had a similar problem. One had to rock the tractor to get it out of gear when on an incline - difficult when you are alone. Had mechanics working on the problem on at least two occasions. The last time they replaced the pilot bearing (which centres trans shaft in the flywheel) - it helped. On a previous occasion some transmission bearings were replaced. Must have something to do with some lateral play on shafts which forces gears together. Not an easy one to fix - probably has to do with general wear.
Big Dean
10-25-2005 12:46:40
If you have multipower they will do that in high range if that what is causing it try shift the multipower in to low range to see if it will shift out of gear.
LCurtis H
10-25-2005 20:53:09
 Re: 1080 Massey hard to shift out of gear in reply to Big Dean, 10-25-2005 12:46:40
I tried your idea and it still does not shift no matter if it is in low or high range on the multi-power.
Thanks Curtis
