Good deal?
Jeg
10-19-2005 17:22:22
Have a chance to buy a MF245. diesel.runs good. dents and dings.missing upper and lower gril cover. clutch adjusted all the way out and probably need replaced. back tires good (spin out rims). front tires and rims suspect. rear remotes. seat bad. lights bad.says 3600 shours but tach not working. 3 point ok. pto ok. multipower. 3 speed. flat top fenders and roll bar.
Asking price $2900
What do you think? supposed to let him know tommorow.
Thanks
GaryF
10-20-2005 16:31:01
 Re: Good deal? in reply to Jeg, 10-19-2005 17:22:22
These were a good tractor 3000 hrs isn't to much.Biggest problem with the diesel engine was smoking when first starting (and hard starting) . This was because of a different design of piston when rebuilt they were changed for the earlier design. Does it have power steering? if so how does it work (THIS CAN BE EXPENSIVE TO FIX)
jf
10-20-2005 10:15:34
I have always thought the way a tractor or combine sheetmetal looks is a good indicator of how it was taken care of mechanicly. If it looks all beat up, then it was ran hard and beat on with-out care. IE - the clutch. My 2 cents.
Case450
10-20-2005 08:44:47
sounds pretty beat up for three thousand hours.
