MF 50 Gear oil?
Jon Snowden
10-17-2005 17:47:27
A friend of mine has a Massey Ferguson MF 50 serial number SGM5I8I75 and needs to know the correct gear oil to put in. Any help would be appreciated. thank you.
Christos
10-19-2005 18:26:30
 Re: MF 50 Gear oil? in reply to Jon Snowden, 10-17-2005 17:47:27
The MF 35/135 and MF 50/150 are the the same beasts, just one is utility and the other is row crop. The engine should take SAE 30 and for the transmission/hydraulic oil you need Massey-Ferguson PermtranIII. Its important for the Hydro/Tranny fluid that you get the PermtranIII fluid as conventional fluid used in those applications will eat away at the seals and gaskets. It should be avalible at an AGCO dealer and its 20 bucks for 3 gallons.
If you can't find an AGCO/M-F dealer, search www.masseyferugson.com or www.agcocorp.com but like I said, permtranIII is the way to go.
Christos
phillip d
10-17-2005 18:00:29
Hi Jon,if the oil that they drained out was thick and smelled like vaseline than it was 80w90 gear oil,which is the case if the tractors hydraulic resivoir is seperate from the rear axel and transmission.If it is all one unit,and the oil was thin and runny,than it needs TDH tractor hydraulic fluid.
Jon Snowden
10-18-2005 10:03:23
 Re: MF 50 Gear oil? in reply to phillip d, 10-17-2005 18:00:29
Thanks for the info, it should help. But part of the problem is that he is pretty sure he has the wrong gear oil in and doesnt know the correct oil to put in but i will relay the information you have provided and it should probably do the trick
