Another MF 35 S/n query
John
07-17-1999 03:56:49
I have recently puchased a MF 35 with a Perkins 3 cylinder engine.The engine s/n is CL 1837786. I would like to know the year of manufacture and model of engine as the S/N Plate of the tractor is missing
Jack in NB
07-18-1999 03:23:56
 Re: Another MF 35 S/n query in reply to John, 07-17-1999 03:56:49
John -
The engine is an A3 152.
My 35 SNM 228771 has engine number CL 1855181C, and SNM 180553 has CL 1807986C, so yours is somewhere between the two.
I'd guess around the 200 000 mark. The SNM in my serial number represents S -standard chassis, N - Perkins diesel, M - dual clutch.
Year - 1959 - 60? (Check production numbers under Specs and Values to the left of this screen.)
Hope this helps.
bob
07-23-1999 15:25:37
 Re: Re: Another MF 35 S/n query in reply to Jack in NB, 07-18-1999 03:23:56
Does your MF 35 have power steering?
I am trying to figure out the model of a local tractor: MF-35 SNM 216*** (I forgot the last three #'s) on the name plate. It has power steering; it even tells you that it's power steering on a little plate around the center of the steering wheel. Air filter canister with attached mason jar on the right side of the hood. 3 cylinder diesel. Dual fuel filters. I did not get the engine #. I really like this tractor and may own it soon regardless of what model it is.
What makes a MF 35 a "Deluxe" or a "Utility" or a "Turf" model as opposed to a regular MF 35?
Any help or other MF sites would be appreciated. I did not get any info on production #'s from the specs and values section.
Thanks.
Joe Ferguson
06-02-2000 10:51:33
 Re: MF 65 Governor in reply to E.Allison, 06-01-2000 10:06:23
Hi
You did'nt mention if it is a gas or diesel
Check.....
If gas carburator adjustment power needle
or fuel supply
Diesel Fuel primary pump or fuel supply
filters and .....
First time I heard governor problem on these models
But it may be defective
Good luck
Joe Ferguson
