massey fergussen small dozer 1970ish
Lanced
10-13-2005 11:28:39
I am looking for a parts supplier for this dozer type, much appreciated for any response.
hector gemme
10-13-2005 13:42:51
 Re: massey fergussen small dozer 1970ish in reply to Lanced, 10-13-2005 11:28:39
HI I have some massey ferguson parts for2244 or 200 .HECTOR
lanced
10-13-2005 14:31:54
 Re: massey fergussen small dozer 1970ish in reply to hector gemme, 10-13-2005 13:42:51
Thanks for the response Hector, I believe mine is a 200 not sure of its year. the dozer has 200 on the side, its a small dozer powered by a 3cyl diesel. It has a 6way blade for a front implement and is set up for 3-point hitch with PTO.
I need track assembly parts for the right side including the track adjuster and the idler wheel bushing and pin or shaft. Is this somthing you may have in sellable shape?
Any input on where I might find parts for this dozer or links would be appreciated, Thanks
hector gemme
10-13-2005 15:05:04
 Re: massey fergussen small dozer 1970ish in reply to lanced, 10-13-2005 14:31:54
HI I have a idler, a yoke with hydrolique jack and a set of chaine 5 1/2 pitch with nice boushing . This parts came from a 2244 MASSEY FERGUSON.HECTOR
lanced
10-13-2005 15:15:16
 Re: massey fergussen small dozer 1970ish in reply to hector gemme, 10-13-2005 15:05:04
is the 2244 the same as the 200 ? Where is this part located?
hector gemme
10-13-2005 15:24:08
 Re: massey fergussen small dozer 1970ish in reply to lanced, 10-13-2005 15:15:16
HI I am locate in MONTREAL CANADA and I am not massey ferguson expert you could contact MASSEY dealer for checking. HECTOR
drig
09-20-2006 20:37:20
 Re: massey fergussen small dozer 1970ish in reply to hector gemme, 10-13-2005 15:24:08
HECTOR I JUST PURCHASED A mf-200 MIGHT NEED A TORQUE CONVERTER.
