I put an MF 40 loader on my 135, and it was specifically designed to fit the 135, so it should fit the 35 as well. Mine had been (badly) adapted to fit a 165. so it required a fair amount of welding and bending things, as well as building my own front frame for it. Therefore it was a relatively long job. Took about 2 days, but id say half of that was driving around trying to find bolts for it! but, if you got one straight off another 35 or 135 it will be a 1 or 2 hour job to fit it. First you fit a plate under the middle of the tractor, 4 bolts and its done - but its not light and was a pain in the are to do on my own, with jacks. One person could easily lift each end and hold it while you bolt it, if they are there. then you will have to bolt a front frame up - another 4 bolts and fit 2 arms from the centre peice (to stop the bottom plate twisting) Then for hydraulics. you need an adapter plate on the cover in front of the seat. 2 bolts and its on the right hand side. Undo the bolts and lift it off. Pull the pipe off the bottom once its out, and change the o rings if you can. then shove this pipe onto the bottom of your new diverter valve and (carefully - dont force it) sit it back down on the pump. It will pop back on easily eniough, but its quite fiddly. Bolt it down (on some of them easier said than done - mine was a bastard) and youre good there. Really you need a power loader, with a cylinder or 2 to tip the bucket. Take a pipe from the diverter valve to a spool block and fron there to the loader. youre good to go! Ben
