We owned a Pony for many years. The parts are very easy to find, so no problem there. It can be used to push snow around, as long as the snow isn't too deep or too heavy. We had a little trouble pulling a single bottom plow in heavy soil, but it did fine in light soil. If you keep the engine in good shape so it's up to full power it can accomplish lighter tasks and some medium tasks with ease. Here are some specs: * Capacity: One 14 inch plow * Performance (Nebraska test no 401) 11.62 hp max. belt; 10.43 hp max. drawbar; max. pull 1432 lbs at 2.57 mph (corrected to sea level basis) 12.16 hp max. belt; 11.08 hp max. drawbar. * Engine: Continental Model N62, L-Head, 4 cylinders vertical, 2 3/8"x3 1/2"-1800 rated rpm. 2050 max. no-load rpm, 2000 to 2050 governed no-load rpm, displacement 62 cubic inches. * Service Data: Champion 18 mm spark plugs, part no. 18625A; 3 rings per piston, 2 compression 3/32", 1 oil 3/16". * Accessories: o Auto-Lite Model GBM-4804-A5 generator standard equipment; o Exide battery standard equipment; o Marvel-Schebler Model TSV-16 carburetor, size 5/8"; o Continental built-in governor; o Canadian Motor lamps; o Donaldson Model A4151 air cleaner; o Purolator Model 749 oil filter, cartridge no. P70; o Rockford single-disc 2-piece clutch, part no. 6-1/2-RM; o National radiator core, capacity 1 4/5 gallons; o Fuel tank capacity 6.8 gallons; o Motor Wheel front and rear wheels o Timken front wheel, rear axle and transmission bearings. * Tires: o Standard-8x24 rear, 4.00x15 front o Oversize-9x24 rear * Brakes: Two brakes located on bull pinion shaft, foot operated either individually or simultaneously by interlocking. * Speeds: o Standard tires-2.74, 3.59 and 7.00 mph, reverse 3.22 mph. o Oversize tires-2.88, 3.77 and 7.35 mph, reverse 3.37 mph * Shipping Weight: 1450 lbs.; * Dimensions: o Wheelbase 66"; o height overall 60"; o width overall, min. 56", max. 80"; o rear wheel tread, min. 41", max 69"; o cultivating clearance 21" with standard tires or 21 1/2" with oversize tires; o turning radius 8 1/2' * Power Take-Off (Optional) 1 1/8" 6 spline shaft, 534 RPM; spline end 26 7/8" above ground, 1 1/4" right of centre line of tractor and 16" ahead of hitch point. * Pulley: (Optional) 6 x 5 1/2", 1990 rated rpm, 2155 governed no-load rpm; belt speed 3130 fpm. * Lubrication: o Crankcase capacity 4 quarts; o transmission case capacity 3 3/5 qts.; o final drive housing 1 1/2 qts.; o 3/4 qt. added for PTO and belt pulley. * Hydraulic Lift: (Optional) o Pesco pump; o 2 1/2 gpm delivery at 1000 psi operating pressure; o reservoir oil capacity 1 1/2 qts. o Double acting cylinder: + 2" inside diameter; + 5" piston stroke; + max. piston force 3140 lbs.; + both push and pull variable stroke control; + cylinder length between pin centres 16"; + 7/8" diameter attaching pin.
