MF 205 diesel in oil
Heetseeker
10-08-2005 13:58:26
I have a 60's MF 205 industrial with the perkins 3 cylinder diesel and it has been a great tractor but i'm getting diesel in the oil. It started out slowly but i'm loosing oil pressure as a result of the leak. I have changed the gasket on the fuel pump cam on the right side and it is still leaking slightly from somewhere. Is there another place that the diesel can get into the pan? I have thought about taking out the pump and blocking off the plate and putting in a electric pump to feed the injection pump. Anyone ever attempt this?
Thanks,
Steve
Big Dean
10-09-2005 15:19:47
 Re: MF 205 diesel in oil in reply to Heetseeker, 10-08-2005 13:58:26
The most common place for diesel to get in the oil is a hole in the diaphragm of the little transfer pump on the right side of the engine the other place is the front seal of the injection pump.
Heetseeker
10-10-2005 06:04:16
 Re: MF 205 diesel in oil in reply to Big Dean, 10-09-2005 15:19:47
Thanks Big Dean,
I thought that might be the culprit...Where can I get the part number for this diaphram?
Steve
